wiring viper 791xv relay to always off
*hss*
Member - Posts: 14
Posted: November 22, 2005 at 8:46 PM / IP Logged
Just like the title says.  I would like to know how can i do that?  I suspect wiring another relay?  I just find it kind of lame that if a thieve disconnect the brain my car will start right up.  I wire my last 791 as per instruction and i find their method weak.
redpeppers
Silver - Posts: 483
Posted: November 22, 2005 at 11:51 PM / IP Logged
english man english......if u are worried about someone disconencting batt......get a back up batt. pack....they work nice......
Where theres is a wire there's a way.
chriswallace187
Gold - Posts: 1,661
Posted: November 23, 2005 at 4:25 AM / IP Logged
You could wire a standalone starter kill relay separate from the viper's. All you need is the relay and a toggle switch. Hook it up as follows:
87a, 86 - key side of cut starter wire
30 - starter side of wire
87 - not used
85 - one side of the toggle switch(the other side of the switch goes to ground).
Hide the toggle switch somewhere away from the alarm brain and you're golden.
C Renner's Auto Electronix
dare_ds69
Silver - Posts: 419
Posted: November 23, 2005 at 4:39 AM / IP Logged
do it a fuel cut off.
how own your mind, control your life.
MECP certified. always use a DMM
gus1
Gold - Posts: 1,013
Posted: November 23, 2005 at 7:04 PM / IP Logged
Or... use the ground when armed off either the brain, or the satellite harness.... wire up a normally open, not so failsafe relay for your starter kill.
Gus
PS: The main thing is to put the brain in such an akward place that unplugging it or even finding it is a very aggrivating experience.
*hss*
Member - Posts: 14
Posted: November 23, 2005 at 7:31 PM / IP Logged
it seems like everyone else understood what i meant.  where in my  sentence did i mention batt?  seems like MY english is fine.
*hss*
Member - Posts: 14
Posted: November 23, 2005 at 7:35 PM / IP Logged
so basically i got to wire another kill switch/relay after the satilite relay?  Man I like the clifford g4 setup better where there relay is normally open.  Also I am going to hide the brain real well.  I was thinking of using my window up button as my "hidden" switch.
chriswallace187
Gold - Posts: 1,661
Posted: November 23, 2005 at 10:44 PM / IP Logged
The 791xv, and every other Viper I've ever seen, are not capable of doing normally open starter kills. You can interrupt the starter wire with a second, toggle-switched relay if you like.
I second the other opinions about why you shouldn't do a fuel cut-off...an intact starter kill will keep the car off just as well as a fuel cut-off without the running hazard.
76eldoconvertfi
Member - Posts: 20
Posted: November 24, 2005 at 6:42 AM / IP Logged
Uh, the Viper 5000 can.
wiring viper 791xv relay to always off -- posted image.
chriswallace187
Gold - Posts: 1,661
Posted: November 24, 2005 at 12:58 PM / IP Logged
My statement still stands; I've never worked with a 5000. That's pretty cool that they are offering that now. The 791 has the starter kill integrated with the miniature relay satellite.
