How to make LEDs Scan
total_overkill
Copper - Posts: 93
Posted: November 25, 2005 at 1:17 AM / IP Logged
I am fairly good with a soldering gun and have a good knowledge in this area. But I am unsure of how to make LEDS scan. Flash is easy. I did a search in this catagory to find any past posts and came up empty. I have been looking on the net for awhile now with no luck. =[ this seems to be a good place to ask though. Thanks in advance for any help.
cowboy21
Copper - Posts: 64
Posted: November 25, 2005 at 2:51 AM / IP Logged
i know u can buy little kits that do it and they are on a circuit board, maybe take the leds out, run wires and mount them where u please
modest yet effective... ECLIPSE 12", Venom 8"x2, Focal 5 1/2" comp.,Response amps x2 (580WRMS total @ 4Ohms), Pioneer TFT + DVD, good for 148.7dB
total_overkill
Copper - Posts: 93
Posted: November 25, 2005 at 2:55 AM / IP Logged
good place to get these kits a name they go by ?
In Canada.
40 grit has saved my life sometimes =[
godblessdremil
Silver - Posts: 273
Posted: November 26, 2005 at 1:35 AM / IP Logged
I dunno about pre-made boards but here are planes to make one.
http://www.bit-tech.net/content_images/knight_rider/normal.gif
Here is the thing its from
http://www.bit-tech.net/article/82/
KPierson
Platinum - Posts: 3,527
Posted: November 26, 2005 at 8:58 AM / IP Logged
I built a flasher for a buddy's S10 a few years back.  I used an Atmel 8bit microcontroller that I custom programmed.  It has 5 I/O pins, I used three for outputs (LED), and 1 for a switch input.  I coded five different patterns that could be selected by pressing the switch.
Simply flashing LEDs with a microcontroller is pretty simple to do, in fact, it was my first ever microcontroller project.  There are quite a few Atmel AVR tutorials on the 'net, and it may be worth looking in to if you are electronically handy.
The beauty of the Atmel microcontroller is that you can buy the chip for $2, and you can build a programmer to program it from a LPT port for another $2.  Very low start up fee to get in to.
Kevin Pierson
boyzWidToys
Member - Posts: 26
Posted: November 26, 2005 at 8:15 PM / IP Logged
scanner needs a special Integrated circuits, and a timer IC, they would be mounted  so that the special IC counts from 1 to.. N (number of leds) and then when reaching N, starts counting down till 1.  And repeat the program.
Its not an easy circuit, unless you know some electronic and logic theory
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
