1994 mercedes E 420, alarm/remote start
adr2dafullest
Posted: November 25, 2005 at 9:52 PM / IP Logged
i need the wiring diagram on this car bad im doing a remote start and alarm system need help hit me up!!!!!!!!!
mo12v
Posted: November 25, 2005 at 10:22 PM / IP Logged
Constant 12 voltsRED & REDIGNITION SWITCH HARNESS *
Ignition 12 voltsPINK/BLACKIGNITION SWITCH HARNESS *
StarterPURPLEIGNITION SWITCH HARNESS *
Dome LightBROWN / GRAY (-)DRIVER KICK PANEL
Trunk Pin SwitchBROWN / YELLOW (-)AT TRUNK LIGHT OR OEM ALARM **
Parking LampGRAY/WHITE & GRAY (+)AT LIGHT SWITCH OR FUSE BLOCK
Power LockBLUEDRIVER KICK PANEL OR
Power UnlockVACUUM DOOR LOCKSAT SUPPLY PUMP UNDER REAR SEAT
Mercedes Vacuum Door Locks. * Remove Instrument Cluster (Pry From Both Sides) To Access Ignition Switch. ** OEM Alarm Control Unit In Trunk (On Pass. Side).
Accessories
Window UpD\ BLK P\ BLK/WHT D\ BLK/VIO P\ BLK/VIO/WHT * SEE NOTES
Window DownF/ GRN F/ GRN/WHT R/ GRN/VIO R/ GRN/VIO/WHT
Ign Key WarnRED / GREEN (+)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsWHITE/ YELLOW (+)AT LIGHT SWITCH
OEM Alarm ArmYELLOW/BLUE (-)DRIVER KICK PANEL OR OEM ALARM **
OEM Alarm DisarmGREEN/ YELLOW (-)DRIVER KICK PANEL OR OEM ALARM **
Reversal Rest At Positive. Location: At Control Module Beneath Rear Seat (Driver Side). ** OEM Alarm In Trunk (Pass. Side). BLUE Unlock Wire Also Disarms OEM Alarm.
Remote Start
Tach SignalGREEN/ YELLOWAT DATA LINK CONNECTOR *
Ignition #2PINK/GREENIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryPINK/BLUEIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightBLACK/ RED / WHITE (+)AT SWITCH ON BRAKE PEDAL BRACKET
Reverse LightGRAY / YELLOW (+)AT FUSE/RELAY BLOCK
Rear Window DefrostBLACK (+)AT SWITCH
* Tach Wire Also Found At Instrument Cluster. NOTE: E-420 And E500 Tach Wire GREEN / WHITE.
MO
