how to make a boot release
tigra
Member - Posts: 11
Posted: November 27, 2005 at 3:22 PM / IP Logged
hi  how can i make a boot relese thanks
joe_1
Silver - Posts: 286
Posted: November 27, 2005 at 3:26 PM / IP Logged
hi, you will need an actuator, spdt relay, and a spare output from your alarm or switch in your car to activate it, what car are you intending to do this to.
i am also a technician so if you have any engine trouble let me know, and i will do my best to help.
tigra
Member - Posts: 11
Posted: November 27, 2005 at 3:33 PM / IP Logged
hi joe  in a fiat punto  whats a actuator
tigra
Member - Posts: 11
Posted: November 27, 2005 at 3:38 PM / IP Logged
any chance of a diagram on how to wire it up thanks
OhioMike1101
Silver - Posts: 343
Posted: November 27, 2005 at 8:18 PM / IP Logged
u can just buy an aftermarket trunk selenoid with button and instructions.  They usually run about $20
We sell them at our store for $19.99
joe_1
Silver - Posts: 286
Posted: November 28, 2005 at 11:44 AM / IP Logged
you can go on ebay and get a boot pop kit, or you can use a central door lock actuator, depending on how strong the return is on the rod on the lock in your boot you may need to add a spring to make the actuator return ready to open the boot again for the next time it is operated, i have never done one on a punto before so i wouldnt beable to give you any tips on that vehicle.
are you running it off a spare output from an alarm or do you want to put a button in the car? let me know  and i can tell you possible wiring set ups.
