LED tail lights VS Incandescents?
blazoner
Member - Posts: 13
Posted: November 28, 2005 at 12:44 PM / IP Logged
How do LED tail-light clusters compare with the traditional incandescent bulbs?
do they have to produce more light to get the same effect?
i'd love to go with absolutely colorless tail light lens assemblies, but i need to know if the colored LED lighting is up to the task....
1996 Mazda Miata M1 is my playtoy!
menace2sobriety
Silver - Posts: 394
Posted: December 03, 2005 at 4:11 AM / IP Logged
yes colored led's are up to the task.  led's respond quicker, shut down faster, last longer and no heat which could be a disadvantage in the winter.
blazoner
Member - Posts: 13
Posted: December 03, 2005 at 8:59 AM / IP Logged
actually, i was referring more to how many Lumens an LED 1157 bulb cluster outputs versus a standard 1157 incandescent bulb.
also, wondering how visibility might be affected during direct sunlight....
thanks!
trap
Posted: December 09, 2005 at 9:45 PM / IP Logged
leds look sweet in tail lights but , they draw less current so your signals will blink tweaker speed and maybe set off a dash light unless you get either some load resistors or a new flasher relay specifically for LED bulbs ...very worth it though,  im sure you have seen the honda civics with with pink altezza brake lights.. white led back up lights are really nifty too
as for visibility during the day they look fine , they have a more defined look to them then normal bulbs and flash much more precise.
