i’m a multimeter dummy
cirrusly_fast
Copper - Posts: 90
Posted: November 28, 2005 at 1:35 PM / IP Logged
I'm trying to measure the voltage that my system in puting out. i put the setting on the multimeter to V. the black lead is connected to the com port on the MM and the red lead is on the v,ohm,m/A port.
now what?
Cuz I'm Kewl Like That.
System: 1-12" Orion H2, Crossfire VR2000D,Odyssey C2150 battery
auex
Platinum - Posts: 5,041
Posted: November 28, 2005 at 1:58 PM / IP Logged
What "system" in peticular are you measuring? If you are measuring electrical then just put the com lead to the neg terminal on the battery and the red lead on the pos terminal on the battery. Also make sure it is the V with the straight line near it and not the V with the wavy line near it.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
placid warrior
Silver - Posts: 357
Posted: November 28, 2005 at 2:38 PM / IP Logged
sounds like he's trying to set his gains with the multimeter, could be wrong though.
DYohn
Platinum - Posts: 10,741
Posted: November 28, 2005 at 2:56 PM / IP Logged
What "output" are you trying to measure?
cirrusly_fast
Copper - Posts: 90
Posted: November 28, 2005 at 3:06 PM / IP Logged
battery, i want to see if the voltage is 12.2 - 14.4
but, i've now confirmed that the amp problem is not due to my car.
cirrusly_fast
Copper - Posts: 90
Posted: November 29, 2005 at 6:13 PM / IP Logged
my mm, however, still doesn't measure anything. damn radioshack crap.
