Audiovox/prestiege rem start
radioflyer
Copper - Posts: 63
Posted: November 29, 2005 at 10:01 AM / IP Logged
i have a 97 silverado with the prestiege remote start/alarm system. after a weekend of work under the hood and having to disconnect the battery, the remote start does not work. I've been told that this could be due to a broken fuse to the main power harness in the remote start. where should I look for this?
thanks
you can never have too much of a good thing
spln4u
Posted: November 29, 2005 at 2:53 PM / IP Logged
If I remember correctly, the prestige systems wont even try to turn over until the tach rate is learned. If it worked fine and all you did was unhook the battery and didnt mess around under the dash, you may need to reprogram the tach rate. Also, did you remove any wires from under the hood that may have been connected to the tach wire?? maybe a wire connected somewhere to the ignition coil??  (refer to the installation manuel for programming the tach rate)
Mark
Sandfly Auto Security
Mike M2
Platinum - Posts: 2,652
Posted: November 29, 2005 at 4:34 PM / IP Logged
I believe the Avox would at least give a 5 chirp to let you know the tach wasn't programmed. Is it doing anything at all when you try to remote start? How about a hood pin? That would make it do nothing, as would the flip switch under the dash being turned off...
Mike M2
Tech Manager
CS Dealer Services
