2006 uplander, relay diagram for bypass
1990mustang
Posted: November 29, 2005 at 4:27 PM / IP Logged
hey guys im installing a remote starter in a 2006 chevy uplander and was wondering if any body has the relay diagram for bypassint the transponder i know it only takes one relay to do and i know we need the extra key head but im not sure were the wires go on the relay.any help is very appreciated.thanx
1990 mustang rollin on 18 inch lexani firestars,custom stereo,twin turbo 5 litre
cntrylvr79
Silver - Posts: 582
Posted: December 01, 2005 at 11:17 PM / IP Logged
You'll need a relay and a good length of about 18ga wire.  wire up as follows take the wire and wrap it around the head of the key 5-6 times and tape it to the key so it doesn't go anywhere.  Then run the wire up to the key cylinder and again wrap it around the antenna on the key cylinder again 5 or six times.  Once you've done that the two ends of that wire, put one end on pin 30 of the relay and the other one to pin 87.  Pin 86 goes to constant +12volt.  Finally 85 goes to a ground when running or status output of the remote start system.
Cause I'm So white and nerdy...
First Class Certi-fried installer
1990mustang
Posted: December 02, 2005 at 11:04 AM / IP Logged
your a life saver thnks alot
