avic-d1
mrhookupz
Member - Posts: 11
Posted: December 01, 2005 at 7:54 PM / IP Logged
i was wondering do i need to get extra stuff for the install other than what comes in the box?????
.:chicago:stunz:.
Hornshockey
Silver - Posts: 520
Posted: December 01, 2005 at 8:07 PM / IP Logged
you'll need a wiring harness for your car and either crimp caps or a solder gun, solder and tape to connect the two harnesses. Depending on the car you may need to look into buying a double din mounting kit for it. You'll also need a wiring diagram to find the parking brake wire and reverse wire.
What model/yr of car is it?
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
mrhookupz
Member - Posts: 11
Posted: December 01, 2005 at 8:09 PM / IP Logged
 i have that what i meant was like a extra part like something for the gps or stuff like that , is a 2005 f150
.:chicago:stunz:.
