2005 Mazda 3, remote start
Welcome Guest :)
marcoux321
Member -
Posted: December 02, 2005 at 3:37 PM / IP Logged
Does anyone have a diagram for 2005 mazda 3 to install remote starter?
Geeque
Silver -
Posted: December 02, 2005 at 3:54 PM / IP Logged
MAZDA
| MODEL | YEAR(S) |
| MAZDA 3 | 2004 -2005 |
| KEY | T-HARNESS | IMMOBILIZER |
| N/A | N/A | MAZDA'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key |
| PART | COLOR | LOCATION | DIAGRAM |
| 12 VOLT CONSTANT | RED (+) and BLACK/ RED (+) | IGNITION SWITCH HARNESS | |
| STARTER | GRAY/BLACK (+) | IGNITION SWITCH HARNESS | |
| STARTER 2 | N/A | | |
| IGNITION 1 | GREEN/ YELLOW (+) | IGNITION SWITCH HARNESS | |
| IGNITION 2 | N/A | | |
| IGNITION 3 | N/A | | |
| ACCESSORY /HEATER BLOWER 1 | PINK / YELLOW (+) | IGNITION SWITCH HARNESS | |
| ACCESSORY /HEATER BLOWER 2 | YELLOW (+) | IGNITION SWITCH HARNESS | |
| KEYSENSE | RED / BLACK (+) | IGNITION SWITCH HARNESS | |
| PARKING LIGHTS ( - ) | BLACK/ WHITE (-) | @ HEADLIGHT SWITCH | |
| PARKING LIGHTS ( + ) | ORANGE / WHITE (+) and ORANGE (+) Use Both, See NOTE *1 | IN PASSENGER KICK PANEL | 26500_MAZDA-3_DUAL PARKING LIGHT DIAGRAM.pdf |
| POWER LOCK | GREEN/ RED (1-Wire Door Lock System) See NOTE*2 | IN DRIVERS KICK PANEL, See DIAGRAM | 14301_3_MAZDA 1 WIRE JBS UNITS.pdf |
| POWER UNLOCK | Same wire, See DIAGRAM | See DIAGRAMS | 14301_3_MAZDA 1 WIRE ALERT SHELBY UNITS.pdf |
| LOCK MOTOR WIRE | YELLOW/BLACK (+) | IN DRIVERS KICK, at DOOR HARNESS | |
| DOOR TRIGGER | See NOTE * 3 | IN PASSENGER KICK PANEL | 14301_3_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf |
| DOMELIGHT SUPERVISION | BLACK/ BLUE to BLACK/ RED (-) | IN PASSENGER KICK PANEL, Harness to REAR of VEHICLE. | |
| TRUNK RELEASE | N/A | | |
| SLIDING POWER DOOR | N/A | | |
| HORN | BLACK (-) | @ STEERING COLUMN HARNESS | |
| TACH | Any wire NOT GREEN/ STRIPE | @ IGNITION COIL | |
| WAIT TO START LIGHT | N/A | | |
| BRAKE | RED / WHITE (+) | @ SWITCH ABOVE BRAKE PEDAL | |
| FACTORY ALARM DISARM | BLACK/ WHITE (-) | IN DRIVERS KICK PANEL, HARNESS TO REAR OF VEHICLE | |
| ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER | |
| NOTES |
| NOTE *1 the (+)Positive PARKING LIGHT Circuit on this vehicle uses (2) PARKING LIGHT wires, to make this connection will require 2 Extra Relays Part #775, to connect, See DIAGRAMNOTE *2 to LOCK requires a (-)Negative thru a 1000 Ohm Resistor, to UNLOCK requires a Straight (-)Negative. Some units will also require 2 extra Relays part #775 to make this connection, See DIAGRAMSNOTE *3 THE LEFT FRONT DOOR IS BLACK / YELLOW (-) ,THE RIGHT FRONT DOOR IS BLACK/ BLUE (-),AND THE RIGHT REAR DOOR IS BLACK/ GREEN (-),THE LEFT REAR DOOR IS BLACK/ ORANGE (-).WHEN CONNECTING TO AN ALARM SYSTEM, USE ALL 4 DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, SEE DIAGRAM. |
| LINK 1 | LINK TEXT 1 | LINK 2 | LINK TEXT 2 |
Gary Kline
MECP Master Technician
marcoux321
Member -
Posted: December 06, 2005 at 9:17 PM / IP Logged
Wednesday, April 29, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
