96 Chevy Pickup alarm/remote start
shyman
Member - Posts: 21
Posted: December 09, 2005 at 9:53 AM / IP Logged
I am a little confused. 1995-97 Chevrolet C/K Pickup Alarm Information
On the wiring diagram it says something about unlocking locking that confuses me. The lock says something about keyless entry. The unlock section says without keyless entry. SO which is it? (My 96 does not have keyless. I know I am looking at it wrong. Can you clarify?
Platinum - Posts: 12,488
Posted: December 09, 2005 at 10:05 AM / IP Logged
5 wire (type C) on the two door models, and positive trigger (type A) on the four door and keyless entry models.
If your truck has no keyless entry and is a 2 door truck, you will need to grab the wires at the driver's door boot and make your connections there. To ensure that you have a 5 wire system, find the WHITE or BLUE wire at the door boot wires and cut one of them in half ( don't worry cause your going to have to cut it anyways if this is a type C system ). When you do this try and toggle your lock and unlock switch, if BOTH functions cease to operate, then you have a 5 wire system.
If only one stops working and the other continues, then you have a Type A system. Both systems you will need to wire in realys. Here is the Type C ( 5 wire ) relay configuration:
http://www.velocitymotorsport.com/images/install_notes/C.jpg
shyman
Member - Posts: 21
Posted: December 09, 2005 at 10:35 AM / IP Logged
Woulndt al of the trucks be one or the other, not both? This truck is a 96 chevy Silvarado king cab 4x4.
So will my remote start unlok bothe doors at the same time even if it is the different system?
shyman
Member - Posts: 21
Posted: December 09, 2005 at 10:40 AM / IP Logged
DO Compustar remote starts come with the relays or do you need to buy them. SO If I understand correctly one relay for locking and one relay for unlocking on the 5 wire system which I probably have because I have a 2 door no keyless entry?
Posted: December 09, 2005 at 10:55 AM / IP Logged
The truck will be one or the other for door lock types. I never trust anything as far as wiring schematics tell me and I ALWAYS check to ensure proper wiring incase one or all the wiring programs that I have is wrong.
Compustar systems require additinal relays for the 5 wire systems. Almost 80 + % of all manufacturer's require external relays for this type of door lock system. You will require two relays for the truck and yes you are correct in your last post.
shyman
Member - Posts: 21
Posted: December 09, 2005 at 12:57 PM / IP Logged
What are the best relays to get and what type are they? Can I go down to my local electrical contractor and get them?
shyman
Member - Posts: 21
Posted: December 12, 2005 at 2:46 PM / IP Logged
Putting in a starter for a 96 chevy full size truck. What is this wire used for and where do I need to connect it?
(It is an orange wire that says it is an accessary wire to the heater negative?) Do I need this?
shyman
Member - Posts: 21
Posted: December 14, 2005 at 7:30 AM / IP Logged
What is the tach wire used for in a remote starter and does a 96 chevy need one or can it go tachless?
mopar_jones
Posted: December 14, 2005 at 9:09 AM / IP Logged
If you're talking about a truck, it's white in a white plug at the ecm on the driver's side inner fender well.
~mtm
dmielken
Copper - Posts: 63
Posted: December 14, 2005 at 9:41 AM / IP Logged
Yes shyman, you will need to hook up the tach input wire of your remote starter to a clean tach signal in your pickup. The remote starter senses the engine starting by ignition tach signal, this prevents your remote starter from overcranking the engine.
Page of 3
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
