Jensen Indash video bypass
lostboy819
Posted: December 13, 2005 at 8:44 PM / IP Logged
I have a Jensen VM9510TS DVD reciver and there is the wire that goes to the parking brake that goes to ground but there is also a GREEN/ White wire that should be hooked up to reverse so if I am useing a back up camera it will override the safety switch. My question is if I do not use a camera do i still need to hook up the GREEN/ white wire ? It shows that wire as + positive.  Also is there a way to bypass the safety switch all together so the kids can watch while im driving?
double-0-push
Posted: December 14, 2005 at 4:58 PM / IP Logged
Just ground the parking brake wire to bypass and cap the GREEN / WHITE reverse wire
lostboy819
Posted: December 14, 2005 at 5:43 PM / IP Logged
That sounds easy enough. thank you for the quick reply
