12 inch neon wiring problem in car
kundi13
Member - Posts: 21
Posted: December 15, 2005 at 5:03 PM / IP Logged
 hi, ive got two 12 inch neons. its got a red +ve and black -ve output wires and also a switch. im having difficulties in wiring them so can anyone help me where to wire them up in the car?
kundi
ss-installer
Silver - Posts: 444
Posted: December 15, 2005 at 8:33 PM / IP Logged
run a fused wire from a power source (battery or key switch) to the toggle. from the toggle to each positive on lights. ground each negative to the car body.
coppellstereo
Silver - Posts: 785
Posted: December 16, 2005 at 4:28 AM / IP Logged
perfect.
kundi13
Member - Posts: 21
Posted: December 17, 2005 at 8:56 AM / IP Logged
i didnt not do that way. i just connected it to the cigeratte lighter , connected the positve and the negative to the cigeratte lighter, is that ok becuase  its working fine?
kundi
hugity
Member - Posts: 14
Posted: December 17, 2005 at 9:23 PM / IP Logged
i did that with my cathodes and it works fine.  its great because the wires to the cigarette lighter are already fused (mine is 25 amps which is more than enough) so yeah, you're good.
Thursday, December 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
