1999 SC2 remote start, tachometer
Krysolma
Member - Posts: 14
Posted: December 20, 2005 at 6:56 PM / IP Logged
Ok, so i instralled a Code Alarm CA425 / CA545 into my gf's SC2.  The wire identification sheet said
TachPURPLE / White Multi Coil Pack or Black at Injector
I used that one and the alarm can't sense the tach input.
Now the instructions say that to test the wire you do this:
1. Set voltmeter to AC VOLTS.
2. Attach positive lead of a volt meter to a constant 12-volt source.
3. Attach negative lead of a volt meter to the wire to be tested.
4. start the engine.
5 have someone press on tthe gas pedal slightly as you monitor the meter.  If connected to the correct wire, the voltage reading will increase as the engine's RPM increases.
Now i did the following and the voltage did change, but it was only about .1 at idel and about .4 at about 3-5k rpm.
Is that wire not the right wire, which wire is it in the pcm.  I know it has to be at the pcm, and its so much easier to get it from there.  thanks guys
chris354
Silver - Posts: 253
Posted: December 20, 2005 at 7:49 PM / IP Logged
Try the white wire at the ignition module on top of the motor.
Krysolma
Member - Posts: 14
Posted: December 22, 2005 at 1:26 PM / IP Logged
Got another problem, in the wiring diagram it said that the door pin wire was under the ash tray.  I found a white wire there that would show (-) when the pass door was open but not the driver.  I probed around and found a wire that would always show (-) when the driver door was open.  So what i did, was i used two IN4001 diodes and hooked it up in exactly this way (below) .  The problem now is that i no longer have a door chime at all.  I can leave the light on and nothing, i can leave key in inginiiton and nothing.  Once in a while it sound like it tries to chime but merely sounds like very faint clicks (not like relay clicks).  Why did this now work.  ????
1999 SC2 remote start, tachometer -- posted image.
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
