DEI 530t, 2001 chevy suburban
sgtfreddyfred
Posted: December 20, 2005 at 11:50 PM / IP Logged
I NEED HELP.....I have a 2001 chevy suburban and I installed a viper 791xv.  I'm trying to add the 530t to my vehicle.  For some reason when I hook everything up, my window just vent up.  Then when I try the driver's switch, it vents up also.  If anyone can tell me what I need to do to get this fixed, I would greatly appreciated it.  Thank you.
Fred
Freddy Fred
coppellstereo
Silver - Posts: 785
Posted: December 20, 2005 at 11:55 PM / IP Logged
you might need a timer to extend the pulse received from activation.  I'm installing one as well - this is my first project, but that sounds like what you might need
528T
Anyone else?
redpeppers
Silver - Posts: 483
Posted: December 21, 2005 at 12:26 AM / IP Logged
did u change the pin switches on the module?  every car requires a different amound of resistance.
Where theres is a wire there's a way.
sgtfreddyfred
Posted: December 21, 2005 at 12:40 AM / IP Logged
Yes, I changed the pin setting and tried all of them and still got the same thing.  I will try the 528
Freddy Fred
Hornshockey
Silver - Posts: 520
Posted: December 21, 2005 at 2:29 AM / IP Logged
you shouldn't need to extend the pulse; the 530T gives your windows one-touch up and down operation. All it needs is a quick pulse to start the cycle. Sounds like you need to try the resistor modification here: http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1900.pdf
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
sgtfreddyfred
Posted: December 21, 2005 at 7:13 PM / IP Logged
I will try that modification and see what happens.  Thanks
Freddy Fred
mobile1
Silver - Posts: 479
Posted: December 22, 2005 at 12:50 AM / IP Logged
ahhh the good old 530t window modification. pain in the butt but should work fine.
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
