2000 buick park ave, crimestopper 1303dp
bry_gordan
Member - Posts: 34
Posted: December 22, 2005 at 4:53 PM / IP Logged
how do you hook up a GM-SL bybpass on a 2000 buick park ave. im using a crimestopper 1303dp
Brian Gordan
mo12v
Posted: December 22, 2005 at 5:27 PM / IP Logged
Connector 1:
BROWN = NEGATIVE Parking Light Output from Crimestopper
BLUE = NEGATIVE Output from Crimestopper while RUNNING
PURPLE = Output DATA to OBDII Purple wire under dash.
WHITE = UNLOCK Output wire from Crimestopper
CYAN = LOCK Output wire from Crimestopper
GRAY / Black = Dome Light Supervision wire from Crimestopper
BLACK / White = TRUNK Output wire from Crimestopper
PINK = IGNITION +
RED = CONSTANT 12 V +
BLACK = GROUND
Connector 2:
WHITE / Black = 2nd UNLOCK Output wire from Crimestopper
WHITE = To Door Trigger
These connections are only needed if the Security Light stays ON when the Key is in the ON Position
PINK / Black = IGNITION Output
PINK = IGNITION Input
MO
bry_gordan
Member - Posts: 34
Posted: December 23, 2005 at 7:14 AM / IP Logged
i have a pk3 key and i hooked up power ground ing and the blue wire to the yellow and black on remote start. my problem is it only starts when key is in ing.i wasnt going to hook up doors only start ther going to keep factory for trunk pop
Brian Gordan
bry_gordan
Member - Posts: 34
Posted: December 23, 2005 at 7:22 AM / IP Logged
where do i get into ing input and ing out put i dont see any security light on in the car it just only starts when key is in ing
Brian Gordan
Skip5015
Posted: December 23, 2005 at 1:33 PM / IP Logged
The Buick has to have a security byass module that is bought seperate from the remote starter. Thats why it only runs with the key in the ignition as it is getting the ok to run from the key. The modules simulate the key with the PK3 systems.
bry_gordan
Member - Posts: 34
Posted: December 26, 2005 at 9:49 PM / IP Logged
using crimestopper1303dp with pldata 4 buypass crimestopper says yellow/black to blue on bypass power ground and ing then purple to light green at ing. harness and thats all on module but it only starts when key is in the ing if i take the key out it will not start do i still need to hook up the orange and ORANGE / black wires i have 2 white wires in a orange sleave which one do i tap into crime stopper says its passlock2c but there is a chip on the key and every thing elese tell me its vatts please help
Brian Gordan
OhioMike1101
Silver - Posts: 343
Posted: December 27, 2005 at 6:46 AM / IP Logged
If it has a resisor in the key, that is usually Vats.  On the Key by the head, you will see PK3 if it is passkey 3.
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
