2001 Excursion remote start
ed langdon
Member - Posts: 8
Posted: December 23, 2005 at 5:40 PM / IP Logged
i installed a ford gold system in a  01 ford excursion with pats bypass . It will crank but wont fire with the remote start .What did i do wrong ?
mo12v
Posted: December 23, 2005 at 6:51 PM / IP Logged
Will it Start with the Key in the Ignition??  ( Not turned ON, just inserted )
MO
ed langdon
Member - Posts: 8
Posted: December 24, 2005 at 6:24 PM / IP Logged
no it will not , it starts fine with the key .remote will not start , tried  holding key next to pats still no go . ED
mo12v
Posted: December 24, 2005 at 8:16 PM / IP Logged
Have you verified ALL your Ignition wires with the Key ( Map your Ignition Circuit )?
Constant 12 voltsL GRN/PPL(2) & YEL(2)IGNITION SWITCH HARNESS
Ignition 12 voltsRED / BLACKIGNITION SWITCH HARNESS
StarterRED / BLUEIGNITION SWITCH HARNESS
Ignition #2GRAY / YELLOWIGNITION SWITCH HARNESS
Ignition #3RED / BLACKIGNITION SWITCH HARNESS **
AccessoryBLACK/ GREENIGNITION SWITCH HARNESS
** There Are Two RED / BLACK Ignition Wires Present At Switch. One RED / BLACK Wire Is A Lighter Shade Of RED And Is The Main Ignition Circuit. The Second RED / BLACK Wire Is A Darker Shade Of RED And Is The Second Ignition
MO
ed langdon
Member - Posts: 8
Posted: December 26, 2005 at 5:11 PM / IP Logged
on the pats wire   instuructions it said        red - crank                  white - crank output (+)    .Where do i find these ?
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
