Lowering Springs
Ravendarat
Platinum - Posts: 2,806
Posted: December 25, 2005 at 7:46 PM / IP Logged
So I just ordered a set of lowering springs and camber correction kits for front and Back for my 99 swift. Does anyone know how hard this is gonna be to put in. I do the audio side for a living but the mechanical side is generally not my thing. If this isnt gonna be that hard I might do it myself, but if its gonna be a bitch I am just gonna pay someone to do it cause I am talking about messing with the suspension on my car and that can be a little dangerous.
speedwayaudio1
Silver - Posts: 879
Posted: December 25, 2005 at 11:57 PM / IP Logged
Pay someone. I never worked on a swift so I can't tell you how hard it is. I will say that you sound like you are not to sure of your self. That tells me right away you should see a pro.
Big Dave
Platinum - Posts: 12,488
Posted: December 26, 2005 at 8:45 AM / IP Logged
You will need spring compressors for the springs and an alignment tool for the camber kit. If you don't have either this will be virtually impossible.
stang351w
Silver - Posts: 350
Posted: December 26, 2005 at 9:08 AM / IP Logged
it can be done by a backyard mechanic as long as they've there competitan. you've gotta remove the shock/struts and take the spprings off, like was mentiond above, use a spring compressor, and make sure its in good condition. if it breaks and you have your fingers or anything in the wrong spot, there's a good chance you'll be visitin the hospital
and the camber kits are usually easly bolted on. just as soon as you do it. call and make a apt with an alignment shop . don't drive around with them not properly aligned because you'll chew up your tires in no time.
Tri County KustomZ
certified installer
Ravendarat
Posted: December 26, 2005 at 9:26 PM / IP Logged
just as I though before, Im callin a shop :)
