06 highlander hybrid r/s
eurocar
Posted: December 26, 2005 at 11:57 AM / IP Logged
Can get the ign to turn on but seems to be a missing ign wire. Have all wires from key switch lit up. if I try with the key on it fires up. Any wiring info would be great!!!
john henrie
eurocarusa@verizon.net
KarTuneMan
Platinum - Posts: 7,056
eurocar
Posted: December 26, 2005 at 2:19 PM / IP Logged
Thanks , had the dei data , there is definatly something missing. It starts w/ key in ign on but not on r/s only. All wires from ign cyl used. They are doing the same as the key. keysense is hooked up.  must be something just on the hybrid, wiring is regular toyota all the way.Thanks again
john henrie
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
