2003 caravan & remote start
golf00
Posted: December 21, 2002 at 7:47 PM / IP Logged
Hi,
Just joined and am hunting info/tips for installing a rm900 remote start from crimestoppers.  I have installed other remote starts but never one where I needed to do relays etc.  I am just wanting start, stop, accessories, and parking lights during remote start run.  The key system is new to me. I have a black key and have been told that the systems with the factory sentry system have grey keys.  I put the system in and I have installed the main ground, hood pin, power (two hot leads to battery), the brake ( purple to tan/white at brake), start one to yellow at switch, and acc to blue/red at switch temporarily set.   The system (box) clicks but does not energize the starter. when the remote is depressed.
I assume that I must need a second ignition wire to the switch (violet/brown with relay) to a 180 to 210 ohm resistor to trigger the ground output of the remote starter.  (never needed it on other plymouth (97) install.)
If this assumtions is true, please let me know.  I have the basic install done, but tommorow I will do the soldering of the wireing and the checkout.
 I do not want to do this over and over so please advise me on my process so far.
securinu
Silver - Posts: 772
Posted: December 21, 2002 at 11:12 PM / IP Logged
you dont have sentry key but the second wire for the resistor is a starter not an ignition also parklights are - thru  5.6k ohm resistor
