2005 Dodge Caravan alarm/remote start
n2mml
Posted: January 02, 2006 at 2:11 PM / IP Logged
I have a 553T Hornet car starter and alarm sysytem. I need the wiring info for a Dodge Caravan 2005. All I want is the car starter to work don't care about alarm system working. I can't find any information on the WEB for this installation. Please if you can help I would appreciate it. Note: I had the car dealer remove this from my 2004 dodge Conversion Van and now I want to install this in my New 2005 Dodge Caravan. They wouldn't do it.
Mharvey
Copper - Posts: 76
Posted: January 02, 2006 at 2:20 PM / IP Logged
REMOTE START
 Battery  LIGHT BLUE/RED (10A)  (+)  IGNITION HARNESS
 Ignition 1  PINK/WHITE  (+)  IGNITION HARNESS
 Accessory 1  VIOLET/ORANGE  (+)  IGNITION SWITCH HARNESS
 Starter 1  YELLOW  (+)  IGNITION HARNESS
 Starter 2  VIOLET/BROWN  (-)  IGNITION HARNESS
 Anti-Theft Type  RF TRANSPONDER
 Anti-Theft Descript  OPTIONAL ON SE MODELS
 Key Sense  LIGHT BLUE  (-)  IGNITION SWITCH HARNESS
 Tachometer  UNCOMMON COLORED WIRE  (AC)  ANY UNCOMMON WIRE AT ANY FUEL INJECTOR
 Parking Lights  WHITE/ ORANGE  (+)  IN HARNESS IN PASSENGER KICKPANEL
 Low Crr. Pk Lights  WHITE/ BROWN  (-)  LIGHT SWITCH OR BCM
 Brake Lights  WHITE/ TAN  (+)  BRAKE PEDAL SWITCH
 Reverse Lights  WHITE/ LIGHT GREEN  (+)  BCM GREEN PLUG
 Horn  DARK GREEN/ VIOLET  (-)  STEERING COLUMN
SECURITY
 All Door Trigger  YELLOW/ORANGE  (-)  AT PCM MODULE BEHIND DRIVERS SIDE OF DASH ON FIREWALL
 Domelight Super  YELLOW/BROWN OR YELLOW/WHITE  (+)  BCM WHITE PLUG
 LF Latch  VIOLET  (-)  BCM WHITE PLUG
 RF Latch  VIOLET/WHITE  (-)  BCM WHITE PLUG
 LR Latch  VIOLET / YELLOW  (-)  BCM WHITE PLUG
 RR Latch  VIOLET/GRAY  (-)  BCM WHITE PLUG
 Trunk Trigger  VIOLET/ORANGE  (-)  BCM WHITE PLUG
 Hood Trigger  BROWN  (-)  AT SWITCH UNDER HOOD
 Alarm Disarm  SEE NOTES...
 Alarm Arm  FACTORY REMOTE ONLY
 Low Crr Pk Lights  WHITE/ BROWN  (-)  LIGHT SWITCH OR BCM
DOORLOCKS/WINDOWS
 Door Lock Circuit  ONE WIRE NEGATIVE RESISTANCE
 Power Unlock  VIOLET/DARK GREEN  (-)  BCM WHITE PLUG
 PowerLock  VIOLET/DARK GREEN  (-)  BCM WHITE PLUG
 Driver Mtr Unlock  TAN/LIGHT GREEN  (REV)  BCM GREEN PLUG
 Driver Mtr Lock  TAN/WHITE  (REV)  BCM GREEN PLUG
 RF Window Up
 Sunroof Open  TO OPERATE SLIDING DOORS SEE NOTES
 Parking Brake  DARK GREEN / WHITE  (-)  PARKING BRAKE SWITCH
 Trnk Release  VIOLET/TAN  (-)  BCM GREEN PLUG
 Seat Mem 1  VIOLET/BROWN  (-)  BCM GREEN PLUG
 Seat Mem 2  SAME WIRE  (-)  BCM GREEN PLUG
BCM IS LOCATED ON DRIVERS SIDE FIREWALL PLUGS FACING TOWARDS STEERING WHEEL
