2005 Suzuki Ario tach signal
mference
Posted: January 03, 2006 at 10:45 AM / IP Logged
Hello all
I am installing a compustar car starter in a 2005 suzuki ario and I can not find a tac signal that is a large enough voltage to be used and the 12 volt siginal needs to be low when starting then high when running and I can not find a stator wire that will work either.
any help would be greatly appreciated !
Mark
jmacf14
Copper - Posts: 160
Posted: January 03, 2006 at 6:02 PM / IP Logged
the only info that i have is for 2002, 2003 aerio and it says  "not black or black white at coil" i would look at the coil and see what color the wires are, test voltage on them with a dmm, ac volts.
jmacf14
jmacf14
Copper - Posts: 160
Posted: January 03, 2006 at 6:05 PM / IP Logged
  check that,   i found 2005 and it says the same.   good luck
jmacf14
Platinum - Posts: 12,488
Posted: January 03, 2006 at 9:41 PM / IP Logged
Use the injector wire found on top of the engine. Remove the cover and the injectors are right there. Use the uncommon colored wire.
mference
Posted: January 04, 2006 at 9:00 AM / IP Logged
thank you all for your help.
I have tryed the not black or black and white the purple is not recognised by this compustar starter.
I will try the injector wire today thank you all again I will poast a reply weather it works or not
Mark
