94 Chevy Caprice
ph0tonik
Posted: December 22, 2002 at 4:04 PM / IP Logged
Hi. I'm getting ready to do a remote start install on my 1994 Chevrolet Caprice and I was wondering if that year had any of the security key features, just making sure I dont have to buy a passlock module from DEI. Thanks.
Platinum - Posts: 12,488
Posted: December 22, 2002 at 8:38 PM / IP Logged
VATS Bypass required...........
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |drivers kick panel          |
|     POWER UNLOCK|white               |+  |drivers kick panel          |
|       LOCK MOTOR|gray                |   |drivers door harness        |
|     UNLOCK MOTOR|tan                 |   |drivers door harness        |
|    DISARM DEFEAT|tan                 |   |passengers door harness     |
| PARKING LIGHTS +|brown               |   |headlight switch *1         |
|       HEADLIGHTS|yellow              |+  |headlight switch            |
|     DOOR TRIGGER|white               |-  |underdash light             |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|dk. green *2        |-  |low in drivers kick panel   |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |at switch                   |
|       TACHOMETER|RED / black           |   |4 pin plug below intake *3  |
|      SPEED SENSE|GREEN / WHITE         |4  |radio harness               |
|       BRAKE WIRE|white               |+  |at brake pedal switch       |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |L of steering column        |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |at drivers door switch      |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |at drivers door switch      |
|  LR WINDOW UP/DN|dk. green - purple  |A  |at drivers door switch      |
|  RR WINDOW UP/DN|lt. green - purple  |A  |at drivers door switch      |
Notes:
*1 Also found to be purple low in the drivers kick panel.  *2 Only available on some models.   *3 Remove the air cleaner assembly to access the connector. The connector is located a few inches from the center of the motor towards the passenger side. The motor will not start with the air cleaner assembly removed.
