2002 Chrysler PT Cruiser Alarm/Remote Start/Stereo Wiring
Lifted77
Posted: December 22, 2002 at 7:52 PM / IP Logged
Does anybody have a chart for a 2002 PT cruiser. I am doing a remote start, and adding door lock actuarors. I would greatly appreciate the help.
Thx.,
LIFTED77
Moderator - Posts: 12,488
Posted: December 22, 2002 at 8:18 PM / IP Logged
|              12V|pink/black & red    |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|WHITE/ green         |*1 |drivers door harness *2     |
|     POWER UNLOCK|same wire           |*1 |drivers door harness *2     |
|       LOCK MOTOR|ORANGE / black        |   |drivers door harness *2     |
|     UNLOCK MOTOR|pink/black          |   |drivers door harness *2     |
|    DISARM DEFEAT|pink/black          |   |drivers kick panel *3       |
| PARKING LIGHTS +|BLACK / YELLOW        |   |drivers kick panel *4       |
|       HEADLIGHTS|PURPLE / white        |+  |steering column *4          |
|     DOOR TRIGGER|*5                  |-  |*5                          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tan/black           |-  |drivers kick panel *3       |
|         HOOD PIN|BROWN / tan           |-  |hood switch or *2           |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|BLACK/ gray          |   |ignition coil               |
|      SPEED SENSE|WHITE/ orange        |   |PCM *6                      |
|       BRAKE WIRE|WHITE/ tan           |+  |brake switch                |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|BROWN / white         |+  |steering column             |
|  LF WINDOW UP/DN|white - lt. blue    |A  |front window switch         |
|  RF WINDOW UP/DN|brn/blu - pur/wht   |A  |front window switch         |
|  LR WINDOW UP/DN|blu/wht - RED / wht   |A  |rear window switch          |
|  RR WINDOW UP/DN|gray - green        |A  |rear window switch          |
|        RADIO 12V|pink                |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|RED / white           |+  |radio                       |
| RADIO ILLUMINATE|BLACK / YELLOW        |+  |radio                       |
|       LF SPEAKER|green - RED / brn     |   |radio or speaker            |
|       RF SPEAKER|pur/grn - blu/red   |   |radio or speaker            |
|       LR SPEAKER|brn/yel - brn/blu   |   |radio or speaker            |
|       RR SPEAKER|blu/wht - blu/blk   |   |radio or speaker            |
Notes:
NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting.   *1 Locks are negative trigger through resistors. Must use relays. Use 3K (3000) ohms for lock/arm and 7.2K (7200) ohms for unlock/disarm. Unlock requires a double pulse.  *2 Also found at the keyless entry module. The keyless module is located above the radio in the center of the dash.    *3 Located in a 26 pin connector. Also found at the keyless module.  *4 Also found at the headlight switch.  *5 The tan or tan/blu wire catches the drivers door and is found in the drivers kick panel. The blue/orange catches the three passenger doors and is found in the passengers kick panel. Use both wires and diode isolate each. Both wires are also found at the keyless module.    *6 The PCM is located under the hood on the drivers side of the firewall.
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
