Where is the high tension wire
teamboss
Posted: January 07, 2006 at 6:05 PM / IP Logged
The remote car start says to hook tke yellow lead to the oil ind. light or high tension wire. Where is it.
Chris Scales
OhioMike1101
Silver - Posts: 343
Posted: January 07, 2006 at 6:33 PM / IP Logged
sounds like it might mean the tach.  Cheap alarms/RS have bad translation issues.
South Side Audio
2501 S. High St
Columbus, OH 43207
sparkie
Platinum - Posts: 2,061
Posted: January 07, 2006 at 8:03 PM / IP Logged
The high tension wire is a spark plug wire. Hopefully your vehicle's ignition system has one you can access. This isn't a very reliable method to use for remote starters. If your system can also hook to a tach wire use it instead.
sparky
