Sub driver surface area vs wattage.
jerseydevil
Member - Posts: 9
Posted: January 10, 2006 at 1:51 PM / IP Logged
Thank you for claifiing things.  IT's helped.  but also raised more questions too.  I was wondering if my situation would benefit from an isobaric setup?  What do you think?  I don't know much about them, other than it offers a reduction in box size and createds the same freq. response.
DYohn
Platinum - Posts: 10,741
Posted: January 10, 2006 at 2:02 PM / IP Logged
Isobaric loading has the advantage of requiring 1/2 the enclosure volume normally required for one woofer and an increase in total power handling over one woofer, but you lose 3db efficiency and do not gain any SPL advantages over one woofer.  It is a good solution for building the smallest possible enclosure for a given driver.
jerseydevil
Member - Posts: 9
Posted: January 10, 2006 at 5:00 PM / IP Logged
Well since I have the room for two with respective boxes.  I guess isobaric isn't really the way to go.  As far as a box goes, I was aiming for a qtc of about .8 which puts the box size at about 11x11x6.  driver requires a cut out of 9 1/8 and a depth of  4 9/16".   0.8 seemed to yield a pretty flat curve in the free box designers.  There was a small +3db around 90hz.   Box volume was about approx .65 ft3.  Infinity recommends a box of .75ft3.   So it's not too far off.
