2005 Impala LS Radio
datni99achris
Posted: January 10, 2006 at 12:33 PM / IP Logged
I Have the Harness (non-Chime Type), It came with an additional red wire( Which I assume is A Power Wire of Some Sort), Where does that red wire connect to? Do any of you all know...I need
kgerry
Platinum - Posts: 3,455
Posted: January 10, 2006 at 2:18 PM / IP Logged
this goes to an acc source on the non-class II harnesses.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
datni99achris
Posted: January 10, 2006 at 2:35 PM / IP Logged
it doesn't have to connect straight to the battery does it? I was told thyat I could hook it to the fuse box...
kgerry
Posted: January 10, 2006 at 5:12 PM / IP Logged
ACC= ACCESSORY.... which obviously would not go directly to the battery
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
memphis11223344
Member - Posts: 34
Posted: January 11, 2006 at 10:05 AM / IP Logged
the acc is a red wire you can hook it up to the yellow wire wich is the 12 votl batt. but the down por to that is that youll always have to turn off the deck manualy when ever you get out of the car. but the red acc wire is a 2nd power source to the head unit
6 memphis PR 15's sealed enclosure. indash mobile video system. alphasonik HC800PMA 3000 rms
MECP first class installer
