92 Safari Van Wirign Diagram
Andyman692
Member - Posts: 35
Posted: May 11, 2002 at 1:28 PM / IP Logged
I need the diagram for this peice of crap can. I found all the wires that wil make the radio work and the radio works fine, but now the hrn and interior lights dotn work. Please tell me whats gonig on and what colors i connect to which....
Andyman692@aol.com
Moderator - Posts: 12,488
Posted: May 11, 2002 at 10:11 PM / IP Logged
GMC
Safari
1988-1994
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
PURPLE OR YELLOW
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
ORANGE
IGNITION SWITCH HARNESS (HEAT/AC) ***
Ignition  #3:
N/A
Accessory:
BROWN
IGNITION SWITCH HARNESS (RADIO/WIPER)
Brake  Light:
WHITE
AT SWITCH ON BRAKE PEDAL BRACKET
Tach  Signal:
WHITE
AT DISTRIBUTOR OR AT COIL *
Parking Lights:
BROWN
(+) AT LIGHT SWITCH
Headlights:
YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Throttle Body Injection Engine. ** GM Rear Wheel Drive Vehicles *** High Current Ignition Wires .
GMC
Safari
1988-1994
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED OR RED
Starter  Kill:
PURPLE OR YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
BLACK/ ORANGE
(-) AT PIN SWITCH ****
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
LIGHT BLUE
DRIVER'S KICK PANEL *****
Power  Unlock:
BLACK/ WHITE OR BLACK
Trunk  Release:
RED
(+) AT RELEASE SWITCH
Alarm  Input Wire:
BLACK/ ORANGE
Notes:
**** If Equipped With Auxillary Lighting Option, Dome Light Can Be Turned Off By A Switch That Interrrupts The The Door Pin Circuit To The Courtesy Lights. If Connection Is Made At This Switch. ***** Positive Pulse Door Lock .
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
