2005 Pacifica Bluetooth
dbfrager
Posted: January 12, 2006 at 2:43 PM / IP Logged
I am planning to install a bluetooth carkit in my wifes 2005 Pacifica. According the the wiring diagram, there is a pin on the radio marked "eva mute". Is this the pin I need to connect the muting wire to inorder to mute the stereo for incoming/outgoing calls?
I also want to run the audio output to the front speakers. The car kit I am looking at, by Motorola, does not require an external amp., so can I just tap into the front speaker wires to enable this?
Thank you
Customautomotiv
Copper - Posts: 128
Posted: January 17, 2006 at 11:10 PM / IP Logged
Try grounding that wire with a computer safe test light. If the radio turns off, then that is your wire. As far as running sound through your audio system....you cant.
You can vote in polls in this forum
