camry driver door priority
alpineivan
Member - Posts: 17
Posted: January 15, 2006 at 11:38 AM / IP Logged
Hi,
need the wiring diagram for the power door locks, so I can isolate the drivers doors actuator from the other doors. So I will have driver door priority. The first signal will open the drivers door and the second output will open all doors.
I need the wire colors for the actuator in the drivers door for the 1997 toyota camry.
thanks
mo12v
Posted: January 15, 2006 at 12:17 PM / IP Logged
Power LockL GREEN20 PIN WHITE CONNECTOR
Power UnlockD GREENIN DRIVER KICK PANEL *
* Child Safety Locks: BLUE/RED (-) In Same Connector As Door Lock Wires.
Drv Door UnlockBLUE12 PIN WHITE CONN. IN DR. KICK PANEL*
* Circuit Type - Reversal Rest At Ground.
BLUE Wire For Driver Door Only Unlock Changes To BLUE/BLACK In 12 Pin Connector In Driver Kick Panel.
MO
Chris Luongo
Platinum - Posts: 3,746
Posted: January 15, 2006 at 7:39 PM / IP Logged
Did the car have factory keyless before?
alpineivan
Member - Posts: 17
Posted: January 16, 2006 at 12:11 AM / IP Logged
No, the car never had a keyless entry before.
Chris Luongo
Posted: January 16, 2006 at 9:11 AM / IP Logged
Okay...... because the models that came with factory keyless had their own driver's-priority feature that made it very easy.
Anyway, I'm sure you can find the wire in the driver's kick panel. You should be able to see pretty clearly the wires coming in through the driver's door boot, and then they'll go to maybe two or three plugs.
Just probe the wires in the plugs until you find one that turns to positive when the doors are unlocked. A common color for Toyotas is blue/black, but you might hafve to test all of them.
HINT: The wire is going to be medium-size, not the thickest or thinnest ones there.
alpineivan
Member - Posts: 17
Posted: January 19, 2006 at 8:58 PM / IP Logged
I found the driver unlock wire, which is blue/black. Thank you mo12v and  Chris Luongo for your detailed instruction.
Now I wonder if you can tell me if I need to cut the wire and install a relay. Or I just spice the driver priority wire from the alarm system into the back / blue wire without using the relay.
Mike M2
Platinum - Posts: 2,652
Posted: January 20, 2006 at 6:36 AM / IP Logged
You will have to use a relay. The wire rests at ground and will need a relay wired 5 wire type.
Mike M2
Tech Manager
CS Dealer Services
alpineivan
Member - Posts: 17
Posted: February 03, 2006 at 4:45 PM / IP Logged
your instructions have walked me through successful installations so far. I got alarm, keyless entry with driver door priority installed successful. There is only one issue left, which is tach wire. I find the tach wire. However, it could not stick my figure to pull it out, so I'll be able to hook the tach wire from the alarm unit into this wire.
My question is : do I have to move the air filter system out of the way to get the tach wire at the ignition coil, or is there other way to get this wire out.
Mike M2
Posted: February 03, 2006 at 5:17 PM / IP Logged
I guess it's a 4 cylinder? You can see the coil on the side of the motor, just stick your hand down there and unplug the gray plug. I'm a big guy and i can get my fat hands down there easy. It's the black wire. You could also just go to an injector wire if you think that's too hard....
Mike M2
Tech Manager
CS Dealer Services
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
