2003 SRT-4, power?
Walkercustoms
Copper - Posts: 219
Posted: January 19, 2006 at 8:39 AM / IP Logged
I am looking at a new system which will contain 2 Visonik V918 X-Class amps and the Visonik 1000watt 4ch and the ma HK15x2. Now the stock alt is 135amps and I will be doing the "Big 3" but, I am not sure the alt will handel the load and I can not find a big alt for the SRT-4 2.4L turbo. Now what are some suggestions I can do to get the most stability with out hurting the power system.
nitris
Member - Posts: 30
Posted: January 19, 2006 at 11:37 AM / IP Logged
buy a high powered performance batter and install a 2 or 3 farid cap and you should be ok
forbidden
Platinum - Posts: 5,352
Posted: January 19, 2006 at 1:34 PM / IP Logged
Ix nay on the cap say. A good battery is going to be a must. Next make the current transfer as best as can be done. The BIG 3 is a must, read the grounding sticky as well as it will definitely apply in this case. See if Stinger will make an alternator for you.
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
