Custom Alternators
aaron9999a
Member - Posts: 14
Posted: January 22, 2006 at 9:36 PM / IP Logged
My Jimmy has a stock alternator at 105 amps. I hooked up an Infinity BD 300 amplifier (1000 watts)with 2 40 amp fuses. It pulls the voltage down to about 12 volts at idle with it not turned up very loud, and still pulls down the voltage with the engine at normal operating RPMs 1500-2500 when the amp is at full power. I plan to add a second one of these at some later date, after I have upgraded the alternator. I've already killed the original alternator, which is sitting in my garage. I replaced it with a like alternator from the parts store, as I did not have the funds to replace it at the time. Anyways, my question is this: What are all of the custom amplifier builders, which is the best, which is the cheapest, which is the best deal, etc.? I'm just trying to get as much info as I can before making a decision on what to get.
Thanks,
~Aaron
nstaller36695
Copper - Posts: 106
Posted: January 23, 2006 at 1:18 AM / IP Logged
try stinger for high output alternators but i personally only use local rebuilders that way in case of malfunctions i dont have to send a customers alternator to florida or california. i am very fortunate to have a local rebuilder that i can trust. also clarify warranty information buyer beware. as always
the best part of a job is seeing the bumper get smaller over the horizon
aaron9999a
Member - Posts: 14
Posted: January 25, 2006 at 3:31 PM / IP Logged
I've gotten quotes from HO Alternators, Stinger, Mechman, and Ohio Alternators. Is there anybody else that I'm missing?
jstruckman
Copper - Posts: 465
Posted: January 25, 2006 at 4:38 PM / IP Logged
Iraggi Alternators, you can find them on Ebay.
Jazzy
ragoal12
Copper - Posts: 135
Posted: January 25, 2006 at 5:55 PM / IP Logged
check out this guys at www.alternatorparts.com very good alternators..
S.O.B custsoms.. South Omaha, Nebraska
akrowfrumsocal
Posted: January 30, 2006 at 1:19 AM / IP Logged
is there anyone on ebay that has low cost high output alternators that are trustworthy? i need to find one that is pumping out 150-250 amps for my 2000 chevy inpala
supradude
Silver - Posts: 915
Posted: January 30, 2006 at 9:34 AM / IP Logged
Look at jstruckman's reply. Iraggi's HO alternators have a good rep.
'85 Toy
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
