viper 791vx with 457gw
pttjr
Member - Posts: 16
Posted: January 24, 2006 at 12:57 PM / IP Logged
Installing a viper 791vx in an 05 Denali, I bought a 457gw with the RS. Is this the best module to use for this application?
mobile1
Silver - Posts: 479
Posted: January 24, 2006 at 1:41 PM / IP Logged
it will work great
stonecole
Copper - Posts: 50
Posted: January 24, 2006 at 3:30 PM / IP Logged
I thought the 791xv came with the remote start?
Hornshockey
Silver - Posts: 520
Posted: January 24, 2006 at 3:42 PM / IP Logged
it does; the 457GW is the databus interface for doorlocks, and bypassing the passlock
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Fastlearner
Silver - Posts: 346
Posted: January 24, 2006 at 3:54 PM / IP Logged
It's a life saver
97f150ext
Copper - Posts: 104
Posted: January 24, 2006 at 8:22 PM / IP Logged
this install is so much easier with the 457, makes install time tons less
pttjr
Member - Posts: 16
Posted: January 25, 2006 at 11:22 AM / IP Logged
Thanks for all the positve replies.
wbwillie2003
Posted: February 06, 2006 at 5:21 PM / IP Logged
97f150ext you wouldnt happen to have the wire info that you hooked the 457 up to?
wbwillie2003
diva
Member - Posts: 21
Posted: February 07, 2006 at 8:24 PM / IP Logged
Okay... first of all, hi everybody!
I started using the 457gw last summer wid viper rs 160, 771 an 791, at least once a week.  Never heard any complaints from customers... seemed everything works for them.  Then I get an 03 tahoe and think "no problem" done a lot of em, right? WRONG!!!
first, the heated seat thing (read that-makes sense)  but then, the perimeter lighting and the lock/unlock wouldn't work.  Disarm would chirp but no unlock, arm would chirp but no lock.  It seemed to stop messing up except for the perimeter lights, so i left it alone.  Now, the locks only work with the factory remote and if u try to remote start it, the factory alarm goes off.  WTF?  Can anyone explain this?  I've done the exact same install on 02-05 tahoe, 03 silverado ss, 03-04 escalades, and now it only messes up in my own friggin car?!
pttjr
Member - Posts: 16
Posted: February 07, 2006 at 8:56 PM / IP Logged
Diva I have not installed my RS yet, but I will keep you posted on my results. What about the heated seats?
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
