1999 Chevrolet Prizm, Prestige aps155ch
luigi04
Posted: February 02, 2006 at 11:18 AM / IP Logged
I have 1999 Chevrolet Prizm with factory power locks.
Want to install Prestige aps155ch, what other parts will I need so I can use the keyless entry?(30 amp relay, qty 1or 2?)
I'm also thinking of buying the power trunk kit, will I need the power relay but not sure what amp (30 amp relay?)
1999 Chevrolet Prizm(Toyota Corolla in disguis)
mo12v
Posted: February 02, 2006 at 5:07 PM / IP Logged
Constant 12 voltsWHITE & BLACK/ REDIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ WHITEIGNITION SWITCH HARNESS
StarterREDIGNITION SWITCH HARNESS
Dome LightRED / WHITE (-)12 PIN CONN. ON BACK OF FUSE BLOCK
Trunk Pin SwitchRED / WHITE (-)AT LIGHT IN TRUNK
Parking LampGREEN (+)12 PIN CONN. ON BACK OF FUSE BLOCK
Power LockBLUE/WHITE13 PIN CONNECTOR *
Power UnlockBLUE / YELLOWIN DRIVER KICK PANEL
Negative Pulse Door Locks
There Are At Least 5 RED / WHITE Wires At The fuse box, some will only pick up individual doors, meter them to find the one that will get all the doors, it will be the one that goes up to the instrument cluster, it is in a 12 pin plug on the back of the fusebox.
* Child Safety Lock - WHITE (-) In 10 Pin IN Driver Kick Panel.
Child Safety Door Locks
Accessories
Window UpD\ YELLOW P\ GRN/RED D\ RED / GRN P\ RED / BLK @ MAIN SWITCH
Window DownF/ GREEN F/ BLU/WHT R/ BLU/BLK R/ BLU/RED
Ign Key WarnBLUE/BLACK (-)13 PIN CONNECTOR IN DR. KICK PANEL
Trunk ReleaseN/A
OEM HornGREEN/ RED (-)STEERING COLUMN HARNESS
HeadlightsRED / WHITE (-)ORANGE 11 PIN CONN. AT FUSE BLOCK
OEM Alarm ArmBLUE/BLACK (-)10 PIN CONNECTOR
OEM Alarm DisarmBLUE/RED (-)IN DRIVER KICK PANEL
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalBLACKAT ENGINE CONTROL MODULE *
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3N/A
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightRED / BLACK (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostN/A
* Engine Control Module Is Located Behind The Center Console.
MO
luigi04
Posted: February 03, 2006 at 12:00 AM / IP Logged
Thank you for the info.
Upon recommendation from a local installer-I purchased from Amazon the Crimestopper CS2200 On-guard Alarm with Wireless Siren, Remote Keyless Entry,and Trunk Open Function($49.99)
CRIME STOPPER CS-611 Power Trunk-Release Kit($17.99)=67.98
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
