90 Cherokee 4.0 tach wire remote start
fram
Member - Posts: 7
Posted: February 02, 2006 at 3:28 PM / IP Logged
I have been trying to program the RPM learn on my autopage 850lcd. I have discovered I tapped into the oil pressure gauge and not the tach feed.
I have gone right to the coil and I find that the wire listed at the green tach wire delivers 13+ volts while the vehicle is running. This is the same at the tach gauge end. I have checked the Factory service Manual to confirm I have the right wire.
My problem is the alarm install manual says I should be getting between 1-6V not the 13v+ I’m getting.
Do I need to hook the tach wire to something else in the Cherokee?
KarTuneMan
Platinum - Posts: 7,056
Posted: February 02, 2006 at 4:47 PM / IP Logged
Tachometer green or grn/wht   AC coil or diag. conn.
fram
Member - Posts: 7
Posted: February 02, 2006 at 8:25 PM / IP Logged
Thanks, I missed the ACV part.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
