M/T Neutral Safety Switch hook up
nccentral
Posted: February 04, 2006 at 7:29 PM / IP Logged
I am installing a add-on remote start, to an existing Viper security system, on a 2002 nissan sentra.  It is a manual transmission but it has a neutral safety switch, which shows 5v when in any other gear but neutral and is grounded when in neutral. My add-on R/S system has a (-) neutral safey switch input that needs to see ground in order to work.
My question is, can i connect those wires directly togeth or do i need to use a relay in someway? Also, if i need to use a relay how would i go about hooking that up?
Powermyster
Silver - Posts: 962
Posted: February 04, 2006 at 7:46 PM / IP Logged
you should be able to tap straight into it. judging by the info that you supplied its straight forward tap in
Why oh Why didn't i take the blue pill
Darren Power
Powermyster
Silver - Posts: 962
Posted: February 04, 2006 at 7:47 PM / IP Logged
Darren Power
dualsport
Silver - Posts: 983
Posted: February 05, 2006 at 11:28 PM / IP Logged
If you can, you might want to do a bench test first and make sure that the R/S disengages when it sees 5V applied-
If it normally expects a 12V swing on the input from open/closed to ground, there may be a chance 5V could be seen as a low. If you can, try even going to 4V or lower to see where the threshold is, to make sure you have enough of a safety margin.
JWorm
Platinum - Posts: 2,208
Posted: February 06, 2006 at 1:13 AM / IP Logged
I did a manual Altima recently. The neutral wire works fine on the BLACK/ white neutral safety input of the 791xv.
To confirm:
After its remote started, and without putting the key in try pushing in the clutch and put the car in gear. As soon as you enter a gear the car should shut off.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
