Pin switch
mrcllusb
Copper - Posts: 489
Posted: February 16, 2006 at 7:09 AM / IP Logged
Who makes the best hood pin switch that actually last??
"ole blake"
Powermyster
Silver - Posts: 962
Posted: February 16, 2006 at 7:32 AM / IP Logged
go with magnetic reed switch.. this is attually the best
Why oh Why didn't i take the blue pill
Darren Power
mrcllusb
Copper - Posts: 489
Posted: February 16, 2006 at 8:45 AM / IP Logged
Do you have a company where you order these from??I know DEI makes a magnetic switch..
"ole blake"
tom badger
Member - Posts: 48
Posted: February 16, 2006 at 1:34 PM / IP Logged
In some situations a mercury switch works good.
The cost is normally around $6.00.
The Badger
sparkie
Platinum - Posts: 2,061
Posted: February 16, 2006 at 2:48 PM / IP Logged
Reed switches can be found at Radio Shack or anywhere that sells home alarms. You need a normally closed one for most remote starters. Mercury switches aren't a good choice as they false and won't work on hills. They haven't been used for many years because of this. Most pin switches are cheap and can be replaced when necessary. If you coat the switch with rust preventative it should last for quite some time.
sparky
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
