Trunk locking hatch problem
only1spooky
Member - Posts: 9
Posted: February 19, 2006 at 4:20 PM / IP Logged
Ok heres a new problem for me lol
One day in my 99 cavi i went to open the trunk only to find out that the hatch lock had broke on the inside
So I went to the junk yard and pulled another one but I got this great idea to have a electric lock instead of the old one so I could wire it to a switch upfront just to hit the botten or wire it into the alarm
However here is my problem
When i first hooked it up it clicked just fine and opened the trunk but now when i hook it up and slam the trunk down it does not work but it will work sometimes if i pull the trunk closed from the cabel on the inside of the trunk ...
Im lost here really starting to get P#$%ed off at it lol
there is one wire running from it that is 12 volt +
it ground to the body of the trunk
Any ideas?
Shane
nydave
Member - Posts: 8
Posted: February 19, 2006 at 5:43 PM / IP Logged
yea it could be how you bolted it is not grounded or the latch was flakey to begin with or it is not pushing the striker is not pushing the catch in all the way. So try allignment and make sure it is grounded properly. Intermitentent problems are tough.
only1spooky
Member - Posts: 9
Posted: February 19, 2006 at 6:05 PM / IP Logged
I checked everything 2 or 3 times to make sure and i added a 3rd ground to it just to make sure.
When it works it works fine when it dont work it does nothing no click no nothing
really odd.
