Use CD audio input for Ipod / Aux?
MickBurke
Member - Posts: 14
Posted: February 20, 2006 at 4:43 PM / IP Logged
I'm trying to install my HK Drive + Play for my IPod, and have found that I don't have an aux input on my head unit (an old Sony MDX-C7900). I currently hooked it up via the CD input and let the CD changer run in the back, while I get the audio from the ipod. problem, of course, is that if the CD changer control cable is not hooked up , i.e. if I remove the CD changer, the CD input is no longer available as an 'input' option. Is there any kind of 'dummy plug' or something I can put on this to trick it into allowing me to select the CD input for the sake of just having the audio input available? I checked my other Sony head unit and it has no aux either, so I'm in a pinch. Any suggestions?? Thanks!
Mick
Ravendarat
Platinum - Posts: 2,806
Posted: February 20, 2006 at 10:24 PM / IP Logged
There are cables made to do exactly what you suggest. I know Dension makes them and I am sure there is a sony brand one as well
coppellstereo
Silver - Posts: 785
Posted: February 20, 2006 at 11:16 PM / IP Logged
I am using a cd changer adapter on my pioneer right now.  It plugs into the changer plug and has 2 rca ends on it.
MickBurke
Member - Posts: 14
Posted: February 21, 2006 at 12:45 AM / IP Logged
Thanks! Not sure if I was clear, and I think the Sony may be different than some of the others. The Sony uses a DIN type plug for the control functions, and a separate set of RCA cables to send the audio to the head unit. I'm looking for something that I can put on the control plug that just enables the RCA inputs. Again, with the Sony, the CD is only selectable if the control cable is connected to the head unit and a changer. I'm trying to track down a 'dummy plug' that will just trick the head unit in to thinking that the CD changer is connected.
Any further input?
Thanks again!
Mick
Ravendarat
Posted: February 21, 2006 at 2:00 AM / IP Logged
Im fully aware of how the sony operates and as I said there is a piece made by dension that will do the job as well as a specific sony piece availible from sony, it can be ordered from any sony repair depot
MickBurke
Member - Posts: 14
Posted: February 25, 2006 at 2:16 AM / IP Logged
Hey, No offense meant... Thanks for the clarification.
Ravendarat
Posted: February 25, 2006 at 2:54 AM / IP Logged
No problem dude. I know you were just clarifying.
Wednesday, December 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
