window problem
ashfieldv
Member - Posts: 20
Posted: February 22, 2006 at 3:31 AM / IP Logged
i installed a roll up window on a 2001 honda civic sedan the problem i am having is that when i use my finger and press the switch in auto the window comes all the way up and then goes down half the way how do i rectify this problem...
also i just installed a remote start car alarm in a 2004 honda civic and everything is kool except for the doors they wont activate neither lock or unlock.....
mrcllusb
Copper - Posts: 489
Posted: February 22, 2006 at 3:40 AM / IP Logged
First thing is to double check all your wiring..Did you wire the remote start correctly to the door locks..
"ole blake"
ashfieldv
Member - Posts: 20
Posted: February 22, 2006 at 3:43 AM / IP Logged
the alarm has negative door locks so does the car..only thing is that the car came originally with keyless entry would that make a difference
mrcllusb
Copper - Posts: 489
Posted: February 22, 2006 at 3:48 AM / IP Logged
No that wouldn't matter.Does it have a chip key?
"ole blake"
ashfieldv
Member - Posts: 20
Posted: February 22, 2006 at 7:18 AM / IP Logged
yes it has a chip key
nava94
Silver - Posts: 296
Posted: February 22, 2006 at 9:22 PM / IP Logged
what kind of module for window.make. what kind of alarm.make.or brand.
audiophd
Member - Posts: 46
Posted: February 24, 2006 at 12:26 PM / IP Logged
to reprogram auto windows you must disconnect power and then reaply power to reset then hold switch down for 10 seconds and the pull up on it for another 10 seconds. had the same problem in my RSX and found out thats the way you have to fix it.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
