2006 Honda Pilot EX-L w/ Navigation
AlvinWang
Member - Posts: 9
Posted: February 26, 2006 at 1:01 PM / IP Logged
Hi Everyone
I was wondering if someone with access to the directed database could post information for the 2006 Honda Pilot. I realize that the wiring is probably unchanged from the '05 Pilot, but for my own peace of mind, I'd really like to see what DEI has on file for my vehicle.
Thanks very much!
AlvinWang
Member - Posts: 9
Posted: March 04, 2006 at 4:07 PM / IP Logged
can anyone help??? just looking for a wiring diagram from DEI...
spookiestylez
Silver - Posts: 531
Posted: March 04, 2006 at 7:47 PM / IP Logged
Pretty sure it hasnt changed,just be sure to test all your wires w/ a DMM
Wiring for 05 Pilot is
12volts
2006 Honda Pilot EX-L w/ Navigation -- posted image.
white (50A)
ignition harness
StarterBLACK/ white + ignition harness
Second StarterN/A
IgnitionBLACK / YELLOW + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessoryyellow + ignition harness
Second AccessoryWHITE/ black + ignition harness
Keysenseblue/black (required) - ignition harness
Power LockBLACK/ orange - pass. fuse box, lt. grn 20 pin plug 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Power Unlockblue/orange - pass. fuse box, lt. grn 20 pin plug 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Lock MotorWHITE/ blue 5widriver fuse box, lt. grn 18 pin plug
Unlock Motoryellow or lt. GREEN/ red 5widriver fuse box, lt. grn 18 pin plug
Parking Lights+RED / black + driver fuse box, lt. grn 20 pin plug
Parking Lights-RED / yellow - headlight switch
Hazardssame as turn signal wires
Turn Signal(L)GREEN / WHITE + turn signal switch
Turn Signal(R)GREEN/ YELLOW + turn signal
Reverse LightGREEN/ black + passenger kick, harness to rear
Door TriggerBLACK/ white - interior light switch on dash 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Dome Supervisionlt. green - interior light switch on dash
Trunk/Hatch Pinblue/black to orange - driver multiplex ctrl unit, pin 8 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Hood Pinyellow/red to yellow - driver multiplex ctrl unit, pin 6 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armblue/white to blue/green - pass. fuse box, lt. grn 20 pin plug 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Factory Alarm DisarmBLACK/ red - pass. fuse box, lt. grn 20 pin plug 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Disarm No UnlockBLACK/ red to blue - driver door module in door 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Tachometerblue ac driver fuse box, lt. grn 10 pin plug 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Wait to startN/A
Brake WireWHITE/ black + brake pedal switch
Parking BrakeGREEN/ red or GREEN/ purple - driver multiplex ctrl unit, pin 15 2006 Honda Pilot EX-L w/ Navigation -- posted image.
Horn Triggerlt. GREEN/ blue - horn switch
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
Interface Modules
MAKE : HONDA | MODEL : PILOT | YEAR : 2005
* The logo is registered trade mark of Honda Corporate.
rtfm
spookiestylez
Silver - Posts: 531
Posted: March 04, 2006 at 7:52 PM / IP Logged
12volts white (50A)  +  ignition harness
Starter BLACK/ white  +  ignition harness
Second Starter N/A
Ignition BLACK / YELLOW  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow  +  ignition harness
Second Accessory WHITE/ black  +  ignition harness
Keysense blue/black (required)  -  ignition harness
Power Lock BLACK/ orange  -  pass. fuse box, lt. grn 20 pin plug
Notes: Meter this wire while pressing the passenger door lock switch.
Power Unlock blue/orange  -  pass. fuse box, lt. grn 20 pin plug
Lock Motor WHITE/ blue  5wi driver fuse box, lt. grn 18 pin plug
Unlock Motor yellow or lt. GREEN/ red  5wi driver fuse box, lt. grn 18 pin plug
Parking Lights+ RED / black  +  driver fuse box, lt. grn 20 pin plug
Parking Lights- RED / yellow  -  headlight switch
Hazards same as turn signal wires
Turn Signal(L) GREEN / WHITE  +  turn signal switch
Turn Signal(R) GREEN/ YELLOW  +  turn signal switch
Reverse Light GREEN/ black  +  passenger kick, harness to rear
Door Trigger BLACK/ white  -  interior light switch on dash
Notes: The driver side door trigger wires are at the driver side fuse box, in a lt. green 10 pin plug. The LF door is GREEN/ orange in pin 3. The LR door is lt. GREEN/ black in pin 10.
The passenger side door trigger wires are at the passenger side fuse box, in a lt. green 20 pin plug. The RF door is WHITE/ orange in pin 16. The RR door is GREEN / WHITE in pin 14. Use all four wires and diode isolate each.
Dome Supervision lt. green  -  interior light switch on dash
Trunk/Hatch Pin blue/black to orange  -  driver multiplex ctrl unit, pin 8
Notes: The driver multiplex control unit is attached to the driver side fuse box. It has a green 22 pin plug on the side of the fuse box facing the firewall.
Hood Pin yellow/red to yellow  -  driver multiplex ctrl unit, pin 6
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm blue/white to blue/green  -  pass. fuse box, lt. grn 20 pin plug
Notes: Meter this wire while turning the key in the passenger door key cylinder. This wire will also lock the doors.
Factory Alarm Disarm BLACK/ red  -  pass. fuse box, lt. grn 20 pin plug
Notes: Meter this wire while turning the key in the passenger door key cylinder. This wire will also unlock the doors.
Disarm No Unlock BLACK/ red to blue  -  driver door module in door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Tachometer blue  ac  driver fuse box, lt. grn 10 pin plug
Notes: Can also go to any ignition coil and use the wire that is NOT BLACK/ white or black.
Can also go to any fuel injector and use the wire that is NOT yellow/black.
Wait to start N/A
Brake Wire WHITE/ black  +  brake pedal switch
Parking Brake GREEN/ red or GREEN/ purple  -  driver multiplex ctrl unit, pin 15
Horn Trigger lt. GREEN/ blue  -  horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models. When using the 556HW, follow the mode 1 wiring diagram. The reference wire is BROWN / yellow, data wire is RED / green and ignition wire is RED / white.
Should Have posted this one first,lol
rtfm
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
