99 Jimmy locks don't work anymore/where to look?
munson
Posted: December 30, 2002 at 11:28 AM / IP Logged
Need help.Worked for two months.I installed a remote start two months ago on a 99 S-15 Jimmy and now the door locks work onlywith the remote control. Door switches don't work any more.The hatch release doesn't work either with the remote control or with the dash switch.The locks fuse #14 is O.K
brianh
Silver - Posts: 518
Posted: December 30, 2002 at 9:03 PM / IP Logged
did you by any chance unplug anything during the install?  Sometimes its easy to not get the connectors plugged back together good.  I would check all factory harnesses that you worked around.. Let us know if you find it.  Brian
munson
Posted: December 30, 2002 at 10:08 PM / IP Logged
I finely got it by checking all fuses.
It was a 3 amps located just over the fog lamps fuse in the main box under the hood.
Called mir/lks
Next step is to replace it by a 5 amp on
brianh
Silver - Posts: 518
Posted: December 31, 2002 at 7:24 AM / IP Logged
Good deal.    Brian
