2006 Chrysler PT Cruiser Radio Wiring
tal-t
Posted: March 02, 2006 at 4:00 PM / IP Logged
I checked the color wire schema for the 2006 PT Cruiser and it does not match up with 2005-2001 wire color.
I have the Standard OEM 2006 PT Cruiser radio and I need the radio wire harness schematics to install an OMNIFI DMP1.
All I need is the Ground, Constant, Dimmer or illumination, and most of all the Switch or ignition wire colors.
tal-t
Posted: March 02, 2006 at 10:41 PM / IP Logged
Ok I got It.
PINK wire with Yellow stripe = Switch(ignition) located on the AC harness
ORANGE wire with Gray stripe = Dimmer located on the AC harness
BLACK wire = ground located on the radio harness
RED = Constant 12V located on the the radio harness
BLACK wire with Yellow stripe = ground located on the radio harness
RED wire with Yellow stripe = Constant 12V located on the radio harness
I guess there are two ground and two constant wires on the radio harness to supply both radio and CD player.
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
