05/06 Mustang door lock wires?
myblugt
Member - Posts: 13
Posted: March 04, 2006 at 9:03 PM / IP Logged
Does anyone know where the door lock wires are for an 05/06 Mustang?
I am installing a remote start/ keyless entry/ alarm and cant find these wires, I found the following but those wires dont exist.
Power Lock:
WHITE/ PURPLE (-) (wire does not exist)
BLACK PLUG AT THE SJB**
Power Unlock:
DK. BLUE/LT. GREEN (-) (wire does not exist)
mo12v
Posted: March 04, 2006 at 9:07 PM / IP Logged
They are there.........look inside the Door Boot between Door & Kick Panel
Power LockWHITE/ PURPLE (-)DRIVER KICK PANEL
Power UnlockD BLUE/LT GREEN (-)DRIVER KICK PANEL
MO
myblugt
Member - Posts: 13
Posted: March 04, 2006 at 9:27 PM / IP Logged
Thanks for your help.
Do you mean inside the rubber boot between the door and car?
Where is the best place to tap into these wires at?
I have installed 5 of these in other cars, never had this much trouble finding wires...
mo12v
Posted: March 04, 2006 at 9:31 PM / IP Logged
YES..............Between Door opening or "door and car"
Once you find them there, you can trace them into the car or tie into them at the boot
Also:
RKE ModuleBUILT INTO SJB (SMART JUNCTION BOX) IN PASSENGER KICK PANEL
MO
myblugt
Member - Posts: 13
Posted: March 04, 2006 at 9:34 PM / IP Logged
Ok,
seems like there would be a better way.
Are you in Iraq now?
05gt
Silver - Posts: 628
Posted: March 05, 2006 at 10:11 PM / IP Logged
when they say the connectors on the SJB you have to take out the three bolts or whatever is holding it in cause there are some more connectors on the back of it
you can also get the lock/unlock wires in the large loom above the gas and brake pedal
joefranco
Posted: March 13, 2006 at 2:21 AM / IP Logged
if you still looking for the wires try on the passenger door remove the kick and the sjb box and the wires should be pink/green pink / YELLOW
techjoe
