2006 Suzuki Reno, lock wiring
spike409
Posted: March 05, 2006 at 3:32 PM / IP Logged
Does anyone have wiring info for Power Door Locks For a 2006 Suzuki Reno?
Spike409
xscash
Copper - Posts: 317
Posted: March 06, 2006 at 7:12 PM / IP Logged
12 VOLT CONSTANT RED (+) IGNITION SWITCH HARNESS
STARTERDARK BLUE (+) or YELLOW (+) IGNITION SWITCH HARNESS
STARTER 2N/A
IGNITION 1PINK (+)IGNITION SWITCH HARNESS
IGNITION 2N/A
IGNITION 3N/A
ACCESSORY /HEATER BLOWER 1ORANGE (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2N/A
KEYSENSEN/A
PARKING LIGHTS ( - )WHITE (-) @ HEADLIGHT SWITCH
PARKING LIGHTS ( + )PURPLE / WHITE (+) and BROWN / WHITE (Right) (+) Must use BOTH, See NOTE *3 IN DRIVERS KICK PANEL, HARNESS TO REAR OF VEHICLE 26500_RENO_DUAL PARKING LIGHT DIAGRAM.pdf
POWER LOCKLIGHT GREEN / WHITE (TYPE B) See NOTE *1 IN DRIVERS DOOR HARNESS 17044_RENO_CENTERAL LOCKING DIAGRAM JBS UNITS.pdf
POWER UNLOCKWHITE to YELLOW (TYPE B) IN DRIVERS DOOR HARNESS 17044_RENO_CENTERAL LOCKING DIAGRAM ALERT SHELBY UNITS.pdf
LOCK MOTOR WIREGRAY/WHITE to GRAY (+) IN DRIVERS DOOR HARNESS
DOOR TRIGGERPURPLE (-) IN DRIVERS KICK PANEL, HARNESS TO REAR OF VEHICLE
DOMELIGHT SUPERVISIONUSE DOOR TRIGGER
TRUNK RELEASEBROWN (+) IN DRIVERS KICK PANEL, HARNESS TO REAR OF VEHICLE
SLIDING POWER DOORN/A
HORNBLACK (-) @ HORN SWITCH
TACHGRAY @ ECM, RED Plug, Pin 25, See NOTE *2
WAIT TO START LIGHTN/A
BRAKELIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM DARK BLUE to LIGHT GREEN (-) IN DRIVERS DOOR HARNESS
ANTI-THEFTN/A
NOTES
NOTE *1 on BASE Models, it may be necessary to add a DOOR ACTUATOR Part #742 for a CENTRAL DOOR LOCKING SYSTEM, to connect, See DIAGRAM
NOTE *2 the ECM (Engine Control Module) is located on the CENTER of the FIREWALL under the HOOD.
NOTE *3 this vehicle uses 2 PARKING LIGHT wires to make this connection will require (2) extra Relays Part #775, to connect, See DIAGRAM
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
