vss, 02 honda civic lx
cap009
Posted: March 06, 2006 at 11:51 AM / IP Logged
I'm installing a Navigation, I need the vss wire color and location in a 2002 civic lx... I really apreciate any help
Platinum - Posts: 12,488
Posted: March 06, 2006 at 2:49 PM / IP Logged
 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column or near center of fusebox.
cap009
Posted: March 06, 2006 at 3:07 PM / IP Logged
I have the vss connected to the white and blue/white, 13 pin green connector over the fuse box.. but the navigation wouldn't give me any guidance, I called kenwood and they said the problem was the connection to that wire, they told me to connect the vss to the WHITE/ green cable behind the glove box and then recalibrate.... there is any difference between this cables??? or do you think i have another problem.
integratyper934
Copper - Posts: 150
Posted: April 04, 2006 at 1:40 AM / IP Logged
on civics ive always used the blue/white behind the gauge cluster or cruise control. the wire has to be behind either of those because of the speedometer.
