12w6
ronnie1313
Posted: March 06, 2006 at 4:56 PM / IP Logged
Hello my fellow installers. Well I have a old 12W6 that I want to use in my suburban. I have a sealed box for it but I ran into a problem its a duel 6 ohm voice coil. So I dont know what to do. I have a Kenwood KAC-929 that I can use or a MA Audio  M1883IX that I can use but I dont know what one would run it better for some good bass. Please give me some insite. I would like to run it hard but not to teh breaking point.
Thank you
Ronnie
arrow12
Silver - Posts: 527
Posted: March 06, 2006 at 6:47 PM / IP Logged
What do mean by "good bass?"  Do you want it to sound good or be loud?  And what are the specs on those amps?
That's my opinion. Take it, leave it, or correct me.
ronnie1313
Posted: March 07, 2006 at 12:56 AM / IP Logged
ok I want it to sound good. here are teh specs I got from the MA audio amp book.
800W MONO block  1x 400W Rms at 4 Ohm mono, 1x 800W Max @ 2Ohm Mono then it list the amp the M188iX amp in the 2 channel amp section with it in mono mode the left +, right- for 4-8Ohm load. Both +-+- used for 2-8Ohm stereo mode. BUT 2 pages later it says M1883iX MONO BLOCK AMP note the M1883iX amp is not a 2 channel amp take caution when connecting subwhoofers to this amp. there are two positive and 2 neg terminals for your convenience when connection a duel voice coil subwoofer. SO THIS IS WHAT I DONT GET.
The Pioneer KAC-929 specs
MAX POWER output at 4 Ohms Normal mode 300x 2 @ 4 Ohms. Bridged is 1000x 1@ 4 Ohms ..... Normal rated power is 150x 2 @4 ohms  460 x 1 @ 4 Ohms  then it also says   230x 2 @ 2 Ohms also so I dont get it I guess need some help hope this give you guys all the info you need.  Hope I get some help I want the bass back in my car.
Ronnie
willdkartunes
Copper - Posts: 250
Posted: March 07, 2006 at 3:09 AM / IP Logged
Ronnie
I think you meant to say Kenwood and not Pioneer....
I would suggest the Kenwood KAC-929. Run it at 460watts x 1 @ 4 ohms. The DVC subwoofer (dual voice coil) is for exactly what you said - your convenience. DVC subs allow different options in wiring the subwoofer to your specific needs. The 6 ohm DVC subwoofer is not a problem at all.  You can wire the subwoofer in series for a 12 ohm load. Refer to the left side column on this website under Car Audio 'woofer wiring' if you need more assistance.This setup will not only sound clean, but keep your amplifier running cooler and living longer. This Kenwood amplifier has a built in fan so running cooler shouldn't be a problem...the living longer part is good though.
stevdart
Platinum - Posts: 5,816
Posted: March 07, 2006 at 10:55 AM / IP Logged
Here's the process you would use to find out which amp is better suited for your sub:
1.  The Kenwood is a two channel amp whose specs say that it will output 460 watts into a bridged 4 ohm load.  It also gives specs for stereo 4 and 2 ohm operation.  To figure out what a 12 ohm bridged load would be, look at the highest impedance (ohm) spec rating:  2 X 150 watts @ 4 ohms.  Use Ohm's Law (double the impedance; halve the power) to find what a stereo load at 8 ohms would be:  2 X 75 watts.  Note:  you are using the highest load rating because your 12-ohm load is high impedance, and you want to use the specified power output of the nearest impedance to yours for your calculation.
A bridged load of 12 ohms is the same output as a stereo load at 6 ohms, the same reason as the more familiar "bridged 4 ohms is the same output as stereo 2 ohms" (notice that in the specs you posted...460 = 2 X 230?).  Now, you know if you wire that sub in series for a 12 ohm load, you have the equivalent of a 2 X 6 ohm impedance.  If the Kenwood amp outputs 2 X 150 watts into 4 ohms, or 2 X 75 watts into 8 ohms...the output for 2 X 6 ohms would be exactly in the middle of those two outputs because 6 is exactly in the middle of 4 and 8.  The amp would output  2 X 112.5, which is 225 watts.  IIRC, this sub is rated up to 300 watts nominal power.  The RMS rating of the sub should be in the forefront of your decision.
2.  You have the option of wiring your sub's coils in parallel for a 3 ohm impedance.  The only amp of the two you have that will accept that load is the mono amp, because as a one-channel amp it is capable of taking a 2 ohm load.  So, figure out how a 3 ohm load will do with the mono amp.  Use RMS numbers if you have them available.  You wrote, "400 watts RMS at 4 ohms, and 800 watts MAX at 2 ohms."  I'm going to guess that the RMS output into 2 ohms for this amp is more like 600 watts.  To find the output into 3 ohms, it's the middle of those two ratings, which should be about 500 watts.  That is too much power for the sub.  Into 12 ohms, it would make 150 watts...not as good as the two channel Kenwood.  wildkartunes suggested the best amp for you to use.
To answer your other question:  a mono amp with two sets of terminals allows flexibility in wiring multiple subs, but only one set could be used just as well.  When two subs are connected using both of these terminal sets, the two are connected in parallel at the amplifier, which halves the impedance (two 4 ohms subs connected this way puts a 2 ohm load on the amp).  Their wording, though, is confusing because they're referring to this method as "stereo".  The warning is because of the drop in impedance if parallel connected at the amp.  And normally a dual voice coil woofer is not wired as they suggested - with one coil to a set of terminals on the amp and the other coil to the other set, because it's simpler to wire the coils together on the sub itself.
ronnie1313
Posted: March 11, 2006 at 9:57 AM / IP Logged
hey thanks alot I will hook it up this weekend..
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
