Honda CRV, Valet Switch
lorrie
Posted: March 09, 2006 at 1:28 PM / IP Logged
I was reading some info regarding valet switches.  My alarm system on 2003 CRV has apparently gone into valet mode.  I tried to take it out by using the instructions in the SecuritySystem handbook, but it did not work.  I called Honda and was told that there is a valet switch located near the floor board, but behind the driver side steering column, and to push this button and insert key.  That would all be just fine, but I cannot locate this button/switch anywhere.  The alarm system was not included on the vehicle at time of purchas but was added and  installed by Honda.  Since it was not factory installed, but was done by Honda, do you think my valet switch is located somewhere different.  OR can someone tell me just exactly what and where I should be looking.   Thanks.
mike swanson
Copper - Posts: 290
Posted: March 09, 2006 at 2:20 PM / IP Logged
Are you sure that honda installed this?
The stealership may have just told you that.
Look for a black box some where under the dash
If ypu find one then look for a name or model #
kgerry
Platinum - Posts: 3,455
Posted: March 09, 2006 at 3:09 PM / IP Logged
they are usually mounted on the upper drivers kick if it's an OEM Alpine alarm.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
mad550
Copper - Posts: 201
Posted: March 09, 2006 at 3:48 PM / IP Logged
Try the fuse panel thats a common location
WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
Platinum - Posts: 12,488
Posted: March 09, 2006 at 4:56 PM / IP Logged
The CPU for the alarm system is bolted at the driver's kick panel. It's a BLACK box with a GREEN connector plugged into the bottom of it.
lorrie
Posted: March 09, 2006 at 5:23 PM / IP Logged
Thanks to all that replied, I really appreciate it.  I believe I have found the black box, on the driver side near the kick panel.  However, I cannot find any type of buttom or switch.  I cannot get underneath to actually see what model it is.  Regardless of the model, am I looking for a button or a switch?  I was told to push the button in, insert key in ignition, then release the button.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
