Side-Post Battery Terminals
iraq_bound?
Copper - Posts: 70
Posted: March 10, 2006 at 12:05 PM / IP Logged
Side-Post Battery Terminals -- posted image.I am having a hard time finding what I want in a side-post battery terminal.,.adapter all I have is one amp for my mids. and highs and a much lager amp for my subs I also have a under-car neon kit and some misc neon's I believe that I need some sort of adapter for the side post a maybe a dist. block to keep it looking cleanSide-Post Battery Terminals -- posted image. Do brands like Stinger have anything to remedy this issue Any Help........??????????
"conspiracy in silence speaks louder than words" -John Lennon
darthness
Copper - Posts: 136
Posted: March 10, 2006 at 12:38 PM / IP Logged
get a side post battery terminal.. run a bigger wire to your trunk (or where ever really) and then use a distrobution block....
kgerry
Platinum - Posts: 3,455
Posted: March 10, 2006 at 12:43 PM / IP Logged
GM side post battery tap available from most accessory companies..... any local install shop will likely have half a dozen in stock
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
iraq_bound?
Copper - Posts: 70
Posted: March 10, 2006 at 3:48 PM / IP Logged
thank you kgerrySide-Post Battery Terminals -- posted image.
coppellstereo
Silver - Posts: 785
Posted: March 10, 2006 at 9:40 PM / IP Logged
Even some car parts stores have them. Well priced, gold plated.
iraq_bound?
Copper - Posts: 70
Posted: March 14, 2006 at 11:29 AM / IP Logged
 Thanks again I picked up a pair of StreetWires side to top post brass/gold-plated from www.crutchfield.com
iraq_bound?
Copper - Posts: 70
Posted: March 14, 2006 at 11:30 AM / IP Logged
did I do that right wow a country boy can leernnnn.........GET IR DONE!!!!
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
