12v output, then bridged?
jamiemcshan
Posted: March 12, 2006 at 6:49 PM / IP Logged
Ok, this is a strange request, but can someone help me figure out how to make some relays do the following.
I would like to be able to use a three way switch, in the first ON position, I would like to drive the relays to output a positive and negative 12 volt output to drive a simple dc motor, but then the other on position would change the output to bridge the + and - that was going to the motor, meaning to dead sort them.  Of course I don't want any voltage at that point.. (that would be a bad thing)  Does that make sense?  You see the motor if you take its two wires and put them together has a built in brake. So I would like to be able to activate that brake in the one position. And power it with the other.
Thanks,
Jamie M.
xscash
Copper - Posts: 317
Posted: March 12, 2006 at 7:51 PM / IP Logged
ok ,you need 4 relays, and your 3 way switch will be ground
relay 1    30 to motor pos......87 to pos.....86 to pos....87a to relay 4-30.....85 to your switch #1 ground
relay 2     30 to motor neg......87 to neg........86 to pos....87a to relay 3-30......85 to 85 on relay 1
relay 3      30 from relay2-87a......87 to relay 4-87.....86 to pos.....85 to your switch #2
relay 4      30 from relay 1-87a.....87 from relay 3-87....86 to pos....85to relay 3-85
there you go,   XS
jamiemcshan
Posted: March 14, 2006 at 9:22 AM / IP Logged
Thank you!
